Hi there,
fresh installed UmbrelOS (1.1 or 1.2) on RaspberryPi4. All works fine until i’ll start with app install. after several minutes the docker container crashed.
umbrel-1718757118677.log (2.1 MB)
I have tried it on different raspberry (including a pi5) as well as various SD cards and also different USB hard drives. all tries with the same result
root@umbrel:/home/umbrel# systemctl status docker
● docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; preset: enabled)
Active: active (running) since Wed 2024-06-19 00:18:15 UTC; 23min ago
TriggeredBy: ● docker.socket
Docs: https://docs.docker.com
Main PID: 470 (dockerd)
Tasks: 82
Memory: 146.2M
CPU: 52.888s
CGroup: /system.slice/docker.service
├─ 470 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
├─ 977 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 2000 -container-ip 10.21.21.6 -container-port 2000
├─ 984 /usr/bin/docker-proxy -proto tcp -host-ip :: -host-port 2000 -container-ip 10.21.21.6 -container-port 2000
├─1672 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 3011 -container-ip 10.21.0.3 -container-port 3011
├─1679 /usr/bin/docker-proxy -proto tcp -host-ip :: -host-port 3011 -container-ip 10.21.0.3 -container-port 3011
├─1729 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 5216 -container-ip 10.21.0.5 -container-port 5216
├─1735 /usr/bin/docker-proxy -proto tcp -host-ip :: -host-port 5216 -container-ip 10.21.0.5 -container-port 5216
├─2008 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 8385 -container-ip 10.21.0.7 -container-port 8385
└─2014 /usr/bin/docker-proxy -proto tcp -host-ip :: -host-port 8385 -container-ip 10.21.0.7 -container-port 8385
Jun 19 00:34:50 umbrel dockerd[470]: time=“2024-06-19T00:34:50.751293788Z” level=info msg=“ignoring event” container=053b01ba3a3b9e39a8de8f089d2dc6668d0f5c5ade51ca04a3>
Jun 19 00:35:38 umbrel dockerd[470]: time=“2024-06-19T00:35:38.431643669Z” level=info msg=“ignoring event” container=074b635d3024ae3239e47e2abb17cbfbe9ecf9ede09cc36275>
Jun 19 00:36:14 umbrel dockerd[470]: time=“2024-06-19T00:36:14.981637075Z” level=info msg=“ignoring event” container=053b01ba3a3b9e39a8de8f089d2dc6668d0f5c5ade51ca04a3>
Jun 19 00:37:02 umbrel dockerd[470]: time=“2024-06-19T00:37:02.359070615Z” level=info msg=“ignoring event” container=074b635d3024ae3239e47e2abb17cbfbe9ecf9ede09cc36275>
Jun 19 00:37:31 umbrel dockerd[470]: time=“2024-06-19T00:37:31.398317785Z” level=info msg=“ignoring event” container=053b01ba3a3b9e39a8de8f089d2dc6668d0f5c5ade51ca04a3>
Jun 19 00:38:00 umbrel dockerd[470]: time=“2024-06-19T00:38:00.646921454Z” level=info msg=“ignoring event” container=074b635d3024ae3239e47e2abb17cbfbe9ecf9ede09cc36275>
Jun 19 00:38:48 umbrel dockerd[470]: time=“2024-06-19T00:38:48.140788134Z” level=info msg=“ignoring event” container=053b01ba3a3b9e39a8de8f089d2dc6668d0f5c5ade51ca04a3>
Jun 19 00:40:01 umbrel dockerd[470]: time=“2024-06-19T00:40:01.965664618Z” level=info msg=“ignoring event” container=053b01ba3a3b9e39a8de8f089d2dc6668d0f5c5ade51ca04a3>
Jun 19 00:40:22 umbrel dockerd[470]: time=“2024-06-19T00:40:22.313280257Z” level=info msg=“ignoring event” container=074b635d3024ae3239e47e2abb17cbfbe9ecf9ede09cc36275>
Jun 19 00:41:19 umbrel dockerd[470]: time=“2024-06-19T00:41:19.498265510Z” level=info msg=“ignoring event” container=053b01ba3a3b9e39a8de8f089d2dc6668d0f5c5ade51ca04a3>
