Debug reporting on unexpected shutdowns
Maybe this functionality exists but I haven’t been able to find it. For some reason, currently unknown to me, my node will go offline at least once a month. The issue is easily resolved by unplugging the node, reflashing the SD card and restarting. However, I can’t figure out why this keeps happening. I am directly connected to an ethernet port on my router. I have the node plugged into a UPS battery. However, every month the node goes offline. Is there anyway to get reporting on this after the fact to identify the root cause?
99% of these issues come from hardware malfunctioning.
A simple power adapter that could not give enough voltage to components is enough to make your node to go off.
Revise them all.
