I have installed Umbrel 2.0 on a UGREEN NAS and after the setup I get this message every 5 minutes on my browser and after some seconds it connects again. Also if I am copying files when that happens then the “copying” process is stuck “preparing..”, most of the times it then fails to finish (especially if I copy from an external hard drive).
The important thing is why am I getting this connection lost message. I use router’s DNS, Ethernet seems correct.. I checked the logs so many times but there are 10 logs every second so I was not able to find any logs with error.. any ideas?
