Can't install Tailscale
Hello Everybody,
I’m pretty new to Umbrel but had everything running, including Tailscale.
But when I wanted to update Tailscale, because the app store said so, it gave an error and won’t update. So I uninstalled Tailscale and tried to install a fresh copy, but now it won’t install. It keeps giving the the following error in the right top corner of the Tailscale web desktop.
It’s in Dutch but the white text says: Installing the app failed.
I found several topics on installing problems but none of them mention this error.
Can someone point me in the right direction or maybe help me solving the problem?
If you haven’t already, I’d try restarting Umbrel from Settings, then installing Tailscale again. Also check that you have some free storage.
If it still fails, go to Settings > Troubleshoot > umbrelOS right after the attempt and download the logs. Could you share the lines around the Tailscale install error here? Have a quick look for any personal info or credentials before posting.
Also, what device are you running Umbrel on, and which umbrelOS version?
