# Cannot Connect 'Error: System service failed'
**URL:** <https://community.umbrel.com/t/cannot-connect-error-system-service-failed/10318>\
**Created:** [November 15, 2022, 6:48am UTC](https://community.umbrel.com/t/cannot-connect-error-system-service-failed/10318 "2022-11-15T06:48:01Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![ilikain](https://avatars.discourse-cdn.com/v4/letter/i/bc8723/32.png) [@ilikain](https://community.umbrel.com/u/ilikain)\
**Post date:** [November 15, 2022, 6:48am UTC](https://community.umbrel.com/t/cannot-connect-error-system-service-failed/10318/1 "2022-11-15T06:48:01Z")
</div>
Very new Umbrel user here. Attempting to build my first node and getting Error: System service failed. Followed the guide and purchased recommended parts. I can connect through ssh, but the debug log isn’t being generated properly (see below). My router is finding the node, but I also cannot connect through the ip address. Not sure what next steps are for debugging the issue.
Microsoft Windows [Version 10.0.19044.2251]
© Microsoft Corporation. All rights reserved.
C:\Users\infin\>ssh -t umbrel@umbrel.local
umbrel@umbrel.local’s password:
Permission denied, please try again.
Linux umbrel 5.10.103-v8+ #1529 SMP PREEMPT Tue Mar 8 12:26:46 GMT 2022 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/\*/copyright.
# Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Thu Nov 3 22:06:38 2022 from fe80::7483:6251:46d7:b9da%eth0 umbrel@umbrel:~ $ vcgencmd get\_throttled throttled=0x0 umbrel@umbrel:~ $ cd umbrel umbrel@umbrel:~/umbrel $ ~/umbrel/scripts/debug
# = Umbrel debug info =
## Umbrel version
0.5.3
## Flashed OS version
v0.5.3
## Raspberry Pi Model
Revision : c03115
Serial : 10000000e1aee29c
## Firmware
Dec 1 2021 15:01:54
Copyright © 2012 Broadcom
## Temperature
temp=32.6’C
## Throttling
throttled=0x0
## Memory usage
Mem: 3.8G 116M 3.5G 8.0M 196M 3.6G
Swap: 0B 0B 0B
total: 3.1%
system: 3.1%
## Memory monitor logs
## Filesystem information
/dev/root 59G 2.9G 54G 6% /
## Startup service logs
– Logs begin at Tue 2022-11-15 05:12:02 UTC, end at Tue 2022-11-15 05:17:01 UTC. –
Nov 15 05:12:10 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Nov 15 05:12:10 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
## External storage service logs
Nov 15 05:12:06 umbrel systemd[1]: Starting External Storage Mounter…
Nov 15 05:12:06 umbrel external storage mounter[472]: Running external storage mount script…
Nov 15 05:12:06 umbrel external storage mounter[472]: Found device “ASMT 2235”
Nov 15 05:12:06 umbrel external storage mounter[472]: Blacklisting USB device IDs against UAS driver…
Nov 15 05:12:06 umbrel external storage mounter[472]: Rebinding USB drivers…
Nov 15 05:12:07 umbrel external storage mounter[472]: Checking USB devices are back…
Nov 15 05:12:07 umbrel external storage mounter[472]: Waiting for USB devices…
Nov 15 05:12:08 umbrel external storage mounter[472]: Waiting for USB devices…
Nov 15 05:12:09 umbrel external storage mounter[472]: Waiting for USB devices…
Nov 15 05:12:10 umbrel external storage mounter[472]: Checking if the device is ext4…
Nov 15 05:12:10 umbrel external storage mounter[472]: No, it’s not ext4
Nov 15 05:12:10 umbrel external storage mounter[472]: Formatting device…
Nov 15 05:12:10 umbrel external storage mounter[472]: wipefs: error: /dev/sda: probing initialization failed: No medium found
Nov 15 05:12:10 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=1/FAILURE
Nov 15 05:12:10 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
Nov 15 05:12:10 umbrel systemd[1]: Failed to start External Storage Mounter.
## External storage SD card update service logs
Nov 15 05:12:10 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Nov 15 05:12:10 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
## Karen logs
## Docker containers
NAMES STATUS
## Umbrel logs
services.tor\_proxy.ports contains an invalid type, it should be a number, or an object
## Tor Proxy logs
# ERROR: The Compose file ‘./docker-compose.yml’ is invalid because: networks.default.ipam.config.subnet is invalid: should use the CIDR format services.tor\_proxy.ports contains an invalid type, it should be a number, or an object services.auth.ports contains an invalid type, it should be a number, or an object services.nginx.ports contains an invalid type, it should be a number, or an object
# ==== Result ====
**Post date:** [November 27, 2022, 1:48am UTC](https://community.umbrel.com/t/cannot-connect-error-system-service-failed/10318/2 "2022-11-27T01:48:21Z")
</div>
Anyone have any suggestions on this? Should I just send the parts back?
