# Can I run Umbrel on safari
**URL:** <https://community.umbrel.com/t/can-i-run-umbrel-on-safari/3245>\
**Category:** General Discussion\
**Created:** [September 7, 2021, 6:03pm UTC](https://community.umbrel.com/t/can-i-run-umbrel-on-safari/3245 "2021-09-07T18:03:31Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![jfpc](https://avatars.discourse-cdn.com/v4/letter/j/d07c76/32.png) [@jfpc](https://community.umbrel.com/u/jfpc)\
**Post date:** [September 7, 2021, 6:03pm UTC](https://community.umbrel.com/t/can-i-run-umbrel-on-safari/3245/1 "2021-09-07T18:03:32Z")
</div>
I was having problems connecting tor on my Mac. It seems to be syncing on safari. Are their any issues I should be aware of? security etc
**Author:** ![abhishandy](https://avatars.discourse-cdn.com/v4/letter/a/77aa72/32.png) [@abhishandy](https://community.umbrel.com/u/abhishandy)\
**Post date:** [September 7, 2021, 7:03pm UTC](https://community.umbrel.com/t/can-i-run-umbrel-on-safari/3245/2 "2021-09-07T19:03:29Z")
</div>
If you are on the same local network, it should be fine.
**Post date:** [September 7, 2021, 7:46pm UTC](https://community.umbrel.com/t/can-i-run-umbrel-on-safari/3245/3 "2021-09-07T19:46:47Z")
</div>
It syncs for awhile (+200k blocks and then crashes)…umbrel doesn’t load on Tor…trying to fix that as well
**Author:** ![lightningpleb](https://yyz2.discourse-cdn.com/flex030/user_avatar/community.umbrel.com/lightningpleb/32/1070_2.png) [@lightningpleb](https://community.umbrel.com/u/lightningpleb)\
**Post date:** [September 8, 2021, 1:35am UTC](https://community.umbrel.com/t/can-i-run-umbrel-on-safari/3245/4 "2021-09-08T01:35:17Z")
</div>
I did have a problem accessing umbrel.local from Safari, but you should be able to use the IP address if you can find it (ie. 192.168.1.123) I started using Firefox, then switched to Tor, so Safari wasn’t really a problem after that.
**Post date:** [September 8, 2021, 11:55am UTC](https://community.umbrel.com/t/can-i-run-umbrel-on-safari/3245/5 "2021-09-08T11:55:46Z")
</div>
Thanks
