Two Questions..
- Can you disable completely wifi and bluetooth? so no RF coming out of the device.
- Can you set this up to run BTC Knots from the start.
Thank You.
G.
Two Questions..
G.
For most, to disable them is a BIOS option. If there is not a BIOS option then no. Of course there is the software option.
I don’t remember, the difference was not that important to me.
